Fire-rated walls for top floor of an over/under duplex? Is it required?
EnvisionMan
Member
Austin, TX
The code book does not address this, so that would normally mean it is not required. But that logic isn't reliable, so...
I am designing an over/under duplex. The ceiling/floor assembly is fire rated (1 hour). The exterior walls of the lower dwelling is also rated (1 hour).
But what about the 2nd floor? Is there any reason for the exterior walls of the top unit to be fire-rated? Again, logic would say no. The code doesn't mention it. But perhaps there is some other reason why my logic is wrong?
p.s. there are no structures within 15 feet of the duplex
Thanks!
Maybe above first floor windows.
I agree, walls supporting the 1 HR rated first floor/ceiling assembly, above that, no requirement..........
ICE said:
He's not looking for a code, he's looking for a reason.
Uh... sorta... if there is a code I am not aware of, then THAT would be a reason as well.
When I say, "Is there a reason..." I don't mean can you think of any sort of silly reason at all... what I mean is has anyone had an inspector quote a passage in the code (that is a reason) or enforce an interpretation of something not exactly in the code (another reason) or simply enforce it because their boss told them to (yet another reason). I want to be prepared for any 'reason' the inspector might throw at me.
Thanks!
