Fire Wall/Barrier Construction
We do a separate inspection as they are constructing the walls. Sometimes it takes 3 or 4 trips but we know it right!
I had a feeling that's what you all would say. I wish we had the time to do that. We're scheduling inspections into mid june already.
What if you encounter a facility that built and you didn't get to? Do you make them hole saw?
I ask because I believe we had an RA try to pull a fast one. Plans said one our needed, plans were inaccurate, and a two hour is needed between both tenants. In this instance, I will definately want to make sure they were constructed accordingly and probably wont get there to watch the construction.
