Floor covering at R2 balcony
pmarx
Bronze Member
If it exists, could anyone please point me to the section in the IFC (2006) that would prohibit putting outdoor carpeting on the wood balcony of an R2 apartment? Thanks.
Unless it is part of an exitway, more than likely allowed
Besides the wood wood also burn, unless FR
agree
Only,
the wood WILL also burn, unless FR. :D
If your concerned about smoke and flame spread index, it is outside.
Thank you cda and fatboy. I thought as much but I'm still bracing for a fight. This arose because of a (general) notice I received from the maintenance office.
I except that I they prohibit me from storing anything on this balcony or in the adjacent “furnace” room per the lease agreement and that the fire code does prohibit me from having a grill but I’ve lived here since 1987 and there was never an issue with the outdoor carpet I’ve used if for no other reason than to keep things from falling through the gaps between the decking onto my downstairs neighbor’s head.
I think some of these other issues are being forced on them by the F.D. When I spoke to the fire marshal’s office yesterday (the F.M. was out), I was told (in a general way I think) that the balcony is considered an "emergency means of egress". I told them I guess that would also prohibit me from screening it in as it has been for the past 20 years (with the approval of the landlord) and was told, “yes it would.” I left my name and number for the F.M. to call me back
First thing I did when I got home last night was to check the sizes of our bedroom double-hung windows which comply with the minimum size required for emergency escape and rescue openings. That back balcony doesn’t enter into the equation.
I am loaded for bear.
wait a minute but that bear in the cage
If management has some governing stuff in the lease, than that trumps the codes
or I know some city apartment code enforcement codes regulate stuff on porches
Suggestion is have management show you in writing what they are tryinig to enforce, and aggree if the balcony is not directly connected to a bedroom, it is not in play
If and when the fire marshal gets back to me, I plan on respectfully asking him what code section governs but also remind him that these particular apartments have emergency escape/rescue windows. It sounds to me that they just want a one size fits all approach to make their jobs easier. As far as the screening, I wasn’t officially notified that it was prohibited and it was done with the approval of the landlord many years ago.
If I was the apartment owner, I wouldn't allow carpet on the wood deck if the deck was exposed to the weather, decks tend to rot out faster with wet carpet on them. Not sure if there is a code for this, though...
The carpeting may hold moisture which in turn could aid in mold growth and deterioration of the wood deck. Find out managements concern about the carpet on the deck. there may be a simple solution you can both agree upon.
As fo the screening the deck, what a FM considers an "emergency means of egress" and what the code defines are usually in the FM's mind only.
Last I looked egrees windows came with screens
The explanation I 've been given about the carpet has always been about "means of egress". "Oh that could catch on fire and block the emegency means of egress." They are probably prohibited on the concrete at grade slabs of the ground floor units too. Thing is, my lease requires that I carpet at least 75% of the inside. I guess that material isn't expected to burn.
Be careful, sometimes deals are made in the permitting stage - the access to the rear balcony may have become mandatory because landscaping was proposed to limit access to some emergency egress windows fromthe outside...... It is easier to require it accross the board than case by case....
The windows may meet the size requirements by code but what does the area ouside the building look like....Is landscaping trees, bushes, shrubs located so that a ladder can be placed and gain easy access to all windows of all bedrooms?
What code section governs what is placed outside of an emergency escape/rescue window and where does it say it has to be easy access for the FD? Is it a good idea to keep these areas clear? Yes but it is not in the code to my knowledge.
mtlogcabin said:
What code section governs what is placed outside of an emergency escape/rescue window and where does it say it has to be easy access for the FD? Is it a good idea to keep these areas clear? Yes but it is not in the code to my knowledge. [/color]
We had that conversation with the fire marshals. They did not want ac units under windows. We pointed out that the unit was well below the window sill so as not to impede egress and would even help the person to get down safely when climbing out the window. They said their guys could not put a ladder up and would not be allowed to climb on the unit. The code is silent on the issue, common sense need to be used.
We have a 2 story apartment complex that have a 20 foot clear space and then carports installed. The FD was upset because the roof of the carports interfered with accessing the 3rd floor with their new ladder truck. The angle of the ladder would hit the carpot roof and the end of the ladder would be above the roof of the apartment.
Nothing in the code to stop the design. It is what it is.
If you have EERO that are inaccessible by the FD, that sort of defeats the purpose, doesn't it? Having a code requiring the EERO is totally useless if you can't access it to effect the rescue.
But the code does not say the window has to be accessible or anything else, gives gives size
I agree. In fact if someone put the head of a bed at the window with a big headboard that blocked the EERO, I'm not sure there is anything that would require them to move it.
Here's an update. The FM returned my call from earlier in the week. Basically I decided not to fight him on the carpet issue even if I had a better than 50-50 chance of winning an appeal. First, it's not really worth the time and effort but more than that, I don't want to be a jerk. He explained that their concern is the heat from a fire below melting a material above that could drip onto the firefighters below. He told me of a recent fire at the complex where the landlord installed 2nd floor aluminum screen door melted and ran down below. OK. Code or not, I don't have a problem protecting someone else so I took the carpet up this past weekend.
He said they were very backed up with school inspections but that he would stop by as soon as he could to review the screen issue. He seemed reasonable and even chuckled when I told him we would be at greater risk from the squirrels and wasps the screens keep out.
I also couldn't find anything in my lease about it either.
You need to pitch your tent at city hall and be a 99%er,
Don't let the man win!!!!!!!!
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
Aluminum siding, trex decking, plastic furniture, EFIS systems and vinyl siding will all melt.
It is still just his want.
mtlogcabin said:
Aluminum siding, trex decking, plastic furniture, EFIS systems and vinyl siding will all melt.It is still just his want.
As an AHJ it has taken several years to try and get rid of the 'as we want' mentality from our department and the 13 fire districts, we have made big strides in that direction; but still find areas we have missed such as lighting in electrical rooms (Thread: Electrical Room Lighting). Every AHJ wants to make safety number one, and sometimes they get carried away. We all need to be reminded every once in while that we can only enforce the code not our wants.
You really should ask for a code section when he does find the time to come over and look at your screens, and let him know that you know the code.
WOW - - - sometimes things are in the code are governed by intent - fortunately, we (our entity) are able to use common sense and require accessibility (by zoning ordiances) for the 5.7 SF windows that are required to be installed by the building and fire codes.
sorry about teh venting, but requring things from the code in design and construction without understanding the intent of the code is like the blind leading the blind.
