CyberPine
Member
About to take on a big challenge and would appreciate any insight and knowledge the team here can offer.
I just put a contract on a vacant 50x100 residential lot in Flagler County Florida. It's very old and in poor condition neighborhood ... mixed built houses and mobiles - nothing nice by any stretch, but It was cheap, near the beach and figured it would suit what I am "trying" to do .. operative word is "trying".
Link to Flagler County Building Dept
My setabacks are 7.5 ft sides, 20 ft rear and 25 feet front.
I'm being told by the county to access water, electric or fence it I must have a building permit for primary dwelling and that primary dwelling must be at least 600 sq feet living space. I have power and water on the lot, but not connected. Any Easier way around getting power, water and fencing without a building permit?
The lot is heavily wooded with Giant oak dead center in the lot I'd like to preserve. In fact, I'd like to somehow build around and under the trees.. is legal and safe to build under big trees?
The lot does not have sewer and Septic will cost me about $5k, but I'm not clear on the sequence for planning . I was told I needed about 10x10 for the tank and about 25x10 from the drain field, but that drain fields can be around trees? how does that work?
I am trying to build something small and simple as an owner-builder getting contractor help along the way. I'd like to build something small, simple and cheap .. something I can build myself without heavy equipment.
I have the application process and am consulting an engineer for guidance but he is going to be expensive.
I have some dumb questions.
1. What's the plans and permit sequence. The Septic guys want a site and floor plan. What kind of Surveys do I need? Elevation? Tree? My engineer is not sure where he can the septic yet and foundation yet.
2. I don't want a tradition CBC or stick house. I'd love to build a house kit, but the County says the kit must be approved with a florida stamp? What kind of stamp?
3. I don't care of the structure is odd or weird, in fact I'd like it to look unorthodox, will anything in code stop me from building modern weird?
4. Any code going to stop me from building a house using a pre-fab steel structure and skin where there is very little framing? I have a particular manufacture called DuroBuildings I am trying to work with but not getting clear answers from them. Must a residential home in Florida be either Block or Wood studs with plywood? Is insulation a building requirement?
DUROSPAN durobuildings.com
5. Just a statement.. but what does it typically take for a Building and Zoning Department to consider new products and new ideas? At what point does a Zoning and Building department accept the Tiny House movement and is there any card I can play?
I actually have 4 days left in my lot Inspection period before I can exit the deal for any reason. Would really appreciate any help or information. If you are sure what I'm trying to do is not going to work, please let me know.
Thank You!
Thank You!
