    Dismiss Notice
Future use areas
Discussion in 'Commercial Building Codes' started by Hyrax4978, Jul 31, 2020.
  1. Hyrax4978
    Hyrax4978 Registered User
    Nov 28, 2016
    115
    5
    I am working on a project in which the owner will only occupy about a quarter of the space.
    The remainder of which is all up in the air pending how they grow and change over the next few years.
    Any recommendations on how to classify the future uses of the area as they grow into it.
    They have ideas on what they might be, but not definite and no idea on how much of each use they might actually end up with.
    Should i classify the entire building as the same use as the part of the building they will occupy, or classify it best as they see it being used in the next few years.
  2. cda
    cda Sawhorse
    Oct 19, 2009
    18,400
    1,307
    1. So what occupancy type is it?
    2. Will they have access/ use of the un finished area?
    3. Fire Sprinkler system?
  3. Hyrax4978
    Nov 28, 2016
    115
    5
    They will start off with F1 use with two fire areas both under 12,000 sf. The future will either be F1, F2 or B uses depending on how things grow and change. No sprinklers.
  4. cda
    cda Sawhorse
    Oct 19, 2009
    18,400
    1,307
  5. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    2,524
    336
    Is this a new building? Do it like a shopping center. One permit for shell and then a separate permit for one tenant fit-out.
    my250r11 likes this.
  6. Hyrax4978
    Nov 28, 2016
    115
    5
    Sorry, yes they will have access. they will occupy about half of one fire area, and the other fire area will have a couple fire shutters.
  7. cda
    cda Sawhorse
    Oct 19, 2009
    18,400
    1,307
    If they have access, they are going to use it, so to me have them label the use.
    And meet minimum code
    Add the comment, Once in the future the area is used for something, plans and permit are required prior to remodel/ use
  8. Tim Mailloux
    Tim Mailloux Registered User
    Feb 12, 2018
    268
    48
    What is the construction type?
  9. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,845
    461
    As usual, It depends.
  10. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,377
    1,133
    I'd have to see a floor plan, but I'd probably call it all F1 or S1....A change of use to B should be simpler than going the other way but it might not make much difference. Bathrooms might be the biggest challenge.
    ADAguy likes this.
  11. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    1,332
    511
    From a code analysis perspective, you have to assign as use to determine the building is within its allowable area. For this purpose, F-1, S-1, M, and B are all pretty similar, so doubtful much impact if a change of use between one of these.
    May ask the AHJ if they do "shell-only" permits. We will offer this for strip malls and similar buildings where the full build out is not completed and the future use is still a bit fluid. A tenant improvement plan is required prior to a CO.
  12. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,987
    675
    Core and shell with tenant finishes, we see it all the time. No reason not to apply it to a single user application.
  13. Mark K
    Mark K Platinum Member
    May 12, 2010
    1,647
    198
    There is more to consider than fire rating. Consider the impact of different occupancies on risk category and design live load. Will there be occupancies associated with hazardous materials.
    Talk to the design team. The future uses may have an impact on the structural system. For example a structural steel frame may make it easier to accommodate future floor openings or new concentrated loads.
  14. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,377
    1,133
    And when the IECC changes and you have to upgrade the insulation and windows in the shell building because it never had a CO?
Share This Page
