RickAstoria
- Joined
- Oct 17, 2009
- Messages
- 531
Re: Garage distance separation from dwelling - Section R309Plan Approver and TJacobs, 2008 Oregon Residential Specialty Code--------------------------------------------------------------R302.1 Exterior walls. Construction, projections, openingsand penetrations of exterior walls of dwellings and accessorybuildings shall comply with Table R302.1. These provisionsshall not apply to walls, projections, openings or penetrationsin walls that are perpendicular to the line used to determine thefire separation distance. Projections beyond the exterior wallshall not extend more than 12 inches (305 mm) into the areaswhere openings are prohibited.Exceptions:1. Detached tool sheds and storage sheds, playhousesand similar structures exempted from permits are notrequired to provide wall protection based on locationon the lot. Projections beyond the exterior wall shallnot extend over the lot line.2. Detached garages accessory to a dwelling locatedwithin 2 feet (610 mm) of a lot line are permitted tohave roof eave projections not exceeding 4 inches002 mm).3. Foundation vents installed in compliance with thiscode are permitted.Table 302.1.JPG[/attachment:qkytxh76]----------------------------------------------------The only thing that mentions lot line is in Exception #2. Detached Garages are ACCESSORY BUILDINGS.This pertains to fire separation construction between a dwelling and an accessory building.TJacobs, when I say substantially parallel and substantially perpendicular.Take a wall on a garage that is diagonal from the dwelling. Lets say it is 10 degrees +/- from being true parallel, I would still treat it as if it was parallel for all portions of the wall within 5-ft. If the wall was say only 10 degrees +/- from perpendicular then I would treat it as perpendicular. The 45 degree mark will be a tricky one. I know the dictionary definition but I am looking at fire conditions and know enough about fire that a wall that is only slightly off from parallel will need the same level of protection as if it was true parallel. Heck, in construction, it will likely not be absolutely true parallel anyway. Its rough framing anyway. So, anyway, it is a judgment call anyway.I had to meet R302.1 as defined above with a garage/accessory workshop on the same lot with the house even though there was a 4-ft. space in between the walls of the dwelling and the accessory building.We treat accessory buildings on the same lot much the same way as if there was a lot line.At the time, I was working with IRC 2006 - 5 ft. rule before 2008 ORSC was adopted with amendments. Taking the stricter of IRC (5-ft.) and the stricter requirements of the 2004/2005 ORSC edition. Fire marshal would want 5-ft. anyway being fire rated. The ones in our area can be an _________. I was aiming to spec 3/4" Type X on both side. Interior and exterior grade. I remember having some questions about that. Some thoughts I had was making that wall portion be some sort of brick faces or CMU / Concrete brick or something of that sort. I would typically build the wall with brick facing and possibly some type of ICF or concrete back wall and 5/8" Type-X on the inside. This would have made construction interesting. It was an interesting thought. I also looked to the fire code as well.
/monthly_2010_05/572953b4f05c0_Table302.1.JPG.d8f429ea1dbb9ea6fa13e1bb7f5319fc.JPG
