Raywesebaum
I am not finding anything specific about where a garage floor drain should go. Does a floor drain to daylight have to have some type of oil water separator?
It is a detached two car garage at a Single Family Residence. It is not a repair facility.Hi Ray,
detached garage? serving how many dwellings if any? how many motor vehicles? is it a repair garage(business of fixing car)?
Does anyone ever go back and inspect the separators to be sure they are working correctly?- NYS requires water oil separator - and they are not cheap.
I do not know much about separators. We inspect oil/gasoline/grease/oil/sand/grit interceptor at final.Does anyone ever go back and inspect the separators to be sure they are working correctly?
Not on a residential property. A County department named Environmental Programs performs periodic inspections of commercial applications.Does anyone ever go back and inspect the separators to be sure they are working correctly?
… at final. But what about a year later? How do you ensure it’s still operating properly?I do not know much about separators. We inspect oil/gasoline/grease/oil/sand/grit interceptor at final.
hope this helps![]()
We don't and probably should. It's seen as maintenance for which the property owner is responsible.… at final. But what about a year later? How do you ensure it’s still operating properly?
