Yankee Chronicler
(For that matter, does the unamended IRC have any limitations as to the allowable area of either the residence or its accessory uses other than height?)
Not that I'm aware of. A single family residence can be as large as the owner wants it to be
Could you hypothetically build a variant of The White House under the the IRC (less than 3 stories above grade, right?) , where the West Wing functions as an accessory structure?
In my opinion, yes. And this brings up an interesting point: The language and punctuation of IRC section R101.2 is ambiguous. Does the three-story limitation apply to one- and two-family dwellings as well as to townhouses, or only to townhouses? The 2021 IRC Commentary suggests that the limitation applies to all, but my understanding has always been (until I just read that Commentary) that the three-story limitation applied only to townhouses, and that one- and two-family dwellings could be any number of stories.
R101.2 Scope. The provisions of this code shall apply to the
construction, alteration, movement, enlargement, replacement,
repair, equipment, use and occupancy, location, removal and
demolition of detached one- and two-family dwellings and
townhouses not more than three stories above grade plane in
height with a separate means of egress and their accessory
structures not more than three stories above grade plane in
height.
