socaldano
OK, to answer the question, like how to get into the garage in a blackout or other failure.   The method to "meet code" is to keep a battery powered circular saw inside the house or courtyard, slyly mark where the 18" vertical studs are. Then in a crisis, you just cut the emergency hole, repair it later (or put a door in the holes place), making sure there is NO plumbing or electrical which you might hit.
I have that "theoretical" problem with a non attached garage where SOMEBODY (me) blocked the side door with stuff so it wont open (it was swollen shut anyways). And apparently someone killed the power to the garage door opener and I can't figure out which of the 5 electrical panels they killed the power. 5 panels you ask????? This started as a 1 bedroom church parsonage. But they started adding on, about 5 additions best I can tell, 3 massive additions are for sure. Half the house is a doctors office the other half is house and additional areas are "living space". So we might have to cut out the windows in the door push someone through to pull the emergency release on the main garage door so we can start tracing the electrical issue.
I might ask the building inspector what is acceptable to the city for a second access. Can I just frame in a window that we can crawl in? Can I make a doggie door or lawnmower door for emergencies. If you have this issue, other houses in your area probably have them.
