would you not consider the columns to be part of the foundation?This hole will be filled with concrete for a patio cover footing. I haven't seen the plans but I am told that it is 60" deep and there are five just like it. Two have a gas pipe passing through. Would you allow the gas pipe to remain with a proper sleeve? (4" ABS)
Yes I would and that allows for a sleeve. Now a second question. Is a patio cover that is open on three sides considered a building that would require the entire length of pipe to be sleeved.would you not consider the columns to be part of the foundation?
IFGC 404 .6
Sure, but IFGC 404 .6 refers to penetrating "building foundation walls," i.e. earth on one side, basement on the other. So that section would not apply to a footing.would you not consider the columns to be part of the foundation?
IFGC 404 .6
Has California adopted the IFGC, or do we just have the CPC Chapter 12?
Ca. Has CPC Chapter 12. I see your point about the basement wall but with no building on either side of a patio post footing my concern is the ability to sleeve through concrete. I suppose the argument could be made that the pipe is parallel in a footing.Has California adopted the IFGC, or do we just have the CPC Chapter 12?
Cheers, Wayne
OK, so 1210.1 says "Underground gas piping shall be installed with sufficient clearance from any other underground structure to avoid contact therewith, to allow maintenance, and to protect against damage from proximity to other structures."Ca. Has CPC Chapter 12.
No settlement is anticipated. Have 4”ABS. What are your thoughts on the patio cover being a building that would require a continuous sleeve?OK, so 1210.1 says "Underground gas piping shall be installed with sufficient clearance from any other underground structure to avoid contact therewith, to allow maintenance, and to protect against damage from proximity to other structures."
Which I would agree precludes encasing it in concrete. But a sleeve through the concrete would seem to me to fit the bill. 4" seems very large for a sleeve, are you expecting 2" of settlement for a patio cover?
Cheers, Wayne
If it was enclosed on 4 sides I would say yes, but 3 would allow for dilution if a leak were to occur.No settlement is anticipated. Have 4”ABS. What are your thoughts on the patio cover being a building that would require a continuous sleeve?
What CPC Chapter 12 reference did they provide?I spoke to the city building department. The bad news is that they will not allow a gas pipe under the patio slab unless it is done per code which would require a vented sleeve for the entire length.
The CPC definition (less exceptions that do not apply):His determination is that a patio cover is a building.
I did not try to argue the point. He did suggest that I could ask the BO. I said that I had been an inspector and would not go over the inspector. That's when the conversation turned to an inquiry about me working for his company.The CPC definition (less exceptions that do not apply):
Building. A structure built, erected, and framed of component structural parts designed for the housing, shelter, enclosure, or support of persons, animals, or property of any kind.
I guess it's hard to argue with the idea that the patio cover is designed for the shelter of persons or property.
Cheers, Wayne
And when they enclose the structure? Then they dig it up and sleeve it?I just spoke to the LA County Mechanical Section and the pipe would be allowed under the patio cover slab in the County jurisdiction.
The patio cover in question is 828 sq.ft. The possibility of it being enclosed is there, However, we deal with the here and now.And when they enclose the structure? Then they dig it up and sleeve it?
An open patio cover does not fit well with the concept of "shelter", for other than sunlight. There's certainly no protection from wind, rain, dust and vermin. Then one must consider "or support" persons, animals, or property of any kind. A picnic table with or without people is being supported.The CPC definition (less exceptions that do not apply):
Cheers, Wayne
I think it does. When I google 'shelter' the first definition I get is "a place giving temporary protection from bad weather or danger." If it's raining, I'd rather be under the patio cover than under no cover. I will be protected from most of the rain (the exception being if I'm near the edge of the cover and it's windy).An open patio cover does not fit well with the concept of "shelter", for other than sunlight.
