mshields
Silver Member
At one time in my career I thought that a GFCI receptacle had to be on the end of the circuit in order that other receptacles on the same circuit would not be ground fault protected also. Conversely if you wanted all receptacles on a circuit to be GFCI, you could simply make the first one GFCI and you'd be done. I've since told that while you can wire an entire circuit to be protected by one GFCI receptacle, you can also wire the one GFCI receptacle such that it does not GFCI protect the others.
This of course is useful where you don't really need GFCI and you want to avoid any nuisance trips you might otherwise get.
Anyway, I was wondering if someone could clarify for me what the story is on this?
Much appreciated,
Mike
Much appreciated,
Mike
