Going from Duplex to Triplex with Grandfathered Laws
John G
Broomfield CO
I am currently in the process of purchasing a duplex and am trying to evaluate wether or not I am able to add a dwelling unit by right. Obviously first thing Monday morning I'm going to have a discussion with someone in the zoning department about this but first wanted to see if anyone had experience with such a scenario.
Currently the property is zoned by the city as R5 High density Residential with a 20 unit acre cap. Property code on the City's record is listed as "dup/triplex land" and it is sitting on just over 1/6 acre of land (.176). The county was annexed in 2001 taking the land from Boulder County.
The only issue I'm seeing is that the minimum lot requirement is 10,000 sqft. Will this present a problem when applying for a building permit for a triplex? (The additional unit will be in the unfinished basement)
Broomfield County Zoning Laws: https://library.municode.com/co/broomfield/codes/municipal_code?nodeId=TIT17ZO_CH17-18HINSREDI
cda
Sawhorse 123
Basement
Not into zoning, will let others speak to that.
Seems like you are not adding to the building size.
Do you know if fire sprinklers might be required??
How will people exit out of the basement?? is there a direct door to the outside?? or have to go up stairs??
And did you take into account each bedroom will either need a door directly to outside or window
fatboy
Administrator
Northern CO
Right after you talk to the Zoning folks, if they green light you, your next stop needs to be the Building Department.......you might be adding fire sprinklers.
John G
Broomfield CO
At this stage I'm most concerned with wether or not it is feasible to even add an additional unit. Sprinklers, means of egress and the like can all be added later.
cda
Sawhorse 123
Basement
Do you have parking for a couple more cars??
Remember what you are looking at is for brand new const.
You might be allowed since the building is there and you are not adding to it
ADAguy
Sawhorse
How much less than 10k is your lot? They will often allow if the difference is <5% or?
Any other triplex in the area?
*****istrator
Palm Beach County Florida
You may never visit this site again for follow-up but just in-case you do:
Although this is strictly a zoning issue at this time, you really may want to heed the advice and get more information about the building requirements. You may get the answer you want from zoning but then you have to comply with the building requirements which may not be feasible to you.
e hilton
Bronze Member
Virginia
He said 1/6 acre or 0.176 acre. That calcs to be 7,666 sf ... a bit more than 10%.
