VLADIMIR LEVIN
I'm in NY, relevant code is 2020 PCNYS. I'm trying to size a grease interceptor for a 3 compartment sink.
Is there anything in the plumbing code other than the grease interceptor being based on the flow rate?
Reason for the question is, I'm calculating a flow rate of 50 GPM which would require a 100 lb capacity interceptor.
I can't fit that in my space.
My calculation is based on the flow rate of all 3 sinks, but in use they wouldn't all be draining at the same time, right?
Is it valid to size the interceptor based on the flow rate from one sink?
