IBC2006,
Section 1009.10 Stairways shall have handrails on each side.
Section 1009.1, exception, allows a stair width to be reduced to 36" if the occupant load is less than 50. This is the case.
Q. I have an exterior exit stairway on a multi-family complex that is 48" wide requiring a minimum handrail or would it require two handrails?
and if it the stair width was 36" wide would it require two handrails? Section 1012.7, the handrail projection into the stair width cannot exceed 4.5". One handrail would give you 31.5". So a 36" wide stairway does not meet the code, correct? it would have to be wider for two handrails.
pc1
pc1
