Christian
Currently there is a double-hung long window which I would like to replace with a glass paneled door of non-combustable materials. The wood stove is a modern mid-size Avalon with a double bestos pipe (straight up to ceiling) which means clearances to back wall,etc. can be closer than old models. California codes were followed to properly install the woodstove.
The closest window side edge nearest woodstove is 27" - 28" a way from its side. (Wood stove front faces away 45 degrees from window: stove door opens opposite direction from proposed doorway.)
People exiting/entering proposed door could pass 33" - 36" from the side of this modern stove - if I position door exactly into the space occupied by the double-hung window.
Would this be okay? Cannot find actual California code regarding this situation.
