    Dismiss Notice
Help with Group R3.1 Sec 420.2
Discussion in 'California' started by Vhin, Aug 9, 2019.
  1. Vhin
    Vhin Registered User
    Aug 9, 2019
    3
    0
    Hi guys,
    I have an issue with compyling with the fire separation in sleeping quarters. Basically, I have an existing structure with 6 ambulatory clients (assisted home care). I wanted to add a room, but the city wants me to make all rooms (existing and new) fire rated. I have no issues putting it in the new addition, but to tear down the walls with existing occupants is going to be a big problem.
    Is there any exception to this requirememt?
    Also, not willing to do firesprinklers.
    Thank you in advance!
  2. cda
    cda Sawhorse
    Oct 19, 2009
    17,994
    1,254
    Welcome
  3. cda
    cda Sawhorse
    Oct 19, 2009
    17,994
    1,254
    So what do you do for a living?
    May help in answering the question
  4. cda
    cda Sawhorse
    Oct 19, 2009
    17,994
    1,254
    Are you able to copy and paste
    420.2
    Not all of us speak California
    This is base code:::
    420.2 Separation walls.
    Walls separating dwelling units in the same building, walls separating sleeping units in the same building and walls separating dwelling or sleeping units from other occupancies contiguous to them in the same building shall be constructed as fire partitions in accordance with Section 708.
    Not sure if they are applying it correctly, or there is more in the calif version or the feds are driving the requirement ??
  5. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,557
    435
    Have you checked with your insurance carrier?
    Is this a single family conversion in a residential neighborhood?
    Is this a licensed care facility?
    Do you live on the site?
  6. Vhin
    Aug 9, 2019
    3
    0
    Thanks CDA, that is the specific code they are pointing out too.
    Im only a designer for a contractor.
    Anything in particular I should be checking with the insurance carrier?
    Yes this is a single family conversion that is already licensed as care facility.
    The owners doesnt live in the house.
    Please let me know any solution to this as the owner doesnt want to do the fire wall, and the city just doesnt want to budge and just points out to the section above.
  7. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    2,440
    317
    They may consider this to be a change of occupancy from R-3 to R-4
    International Existing Building Code
    SECTION 407
    CHANGE OF OCCUPANCY
    407.1 Conformance. No change shall be made in the use or
    occupancy of any building unless such building is made to
    comply with the requirements of the International Building
    Code for the use or occupancy. Changes in use or occupancy
    in a building or portion thereof shall be such that the existing
    building is no less complying with the provisions of this code
    than the existing building or structure was prior to the change.
    Subject to the approval of the building official, the use or
    occupancy of existing buildings shall be permitted to be
    changed and the building is allowed to be occupied for purposes
    in other groups without conforming to all of the
    requirements of this code for those groups, provided the new
    or proposed use is less hazardous, based on life and fire risk,
    than the existing use.
  8. cda
    cda Sawhorse
    Oct 19, 2009
    17,994
    1,254
    For a house, I do no think I have seen the one hour requirement for separating
    “Bedrooms”
    Which is basically what you have.
    And not like a motel set up where there are separate sleeping units.
    I am not near the commentary for a few weeks so not sure how it reads???
    Buller Buller
    If this is also inspected by the state or feds, I would ask them what the requirements are!!!!
    Plus they may have additional!!
  9. ADAguy
    Sep 11, 2013
    4,557
    435
    See state requirements for assisted care facilities.
    Insurance: owner may not have indicated this as assisted care facility.
    Have you addressed CBC 11B / ADA?
    Also, is this a privately funded or government funded facility?
    Is this a design/build project?
    Are you an architect?
  10. Vhin
    Aug 9, 2019
    3
    0
  11. cda
    cda Sawhorse
    Oct 19, 2009
    17,994
    1,254
  12. cda
    cda Sawhorse
    Oct 19, 2009
    17,994
    1,254
    With the city, is there a magic number of clients,,,
    Where the rated walls kicks in???
  13. cda
    cda Sawhorse
    Oct 19, 2009
    17,994
    1,254
    There are some California people on here. Wait till next week and see how they reply.
    Does calif use the IEBC??
    You can also look at
    SECTION 722
    CALCULATED FIRE RESISTANCE
    To see what the existing walls calculate out to.
Share This Page
