    Dismiss Notice
High-Rise Communicating Stair
Discussion in 'Commercial Building Codes' started by HVACQuestions, Sep 23, 2019.
  1. HVACQuestions
    HVACQuestions Registered User
    Sep 23, 2019
    5
    0
    HVAC designer here, I'm working on a job with an existing high rise tower with a communicating stair connecting 2 floors. The architect wants to cut another hole in the ceiling to have this stair connect 3 floors. I'm trying to figure out any mechanical implications of them doing so; is there a section of the IBC that governs fire protection/smoke concerns with communicating staircases? I thought it had to do with the size of the stair opening.
  2. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    2,052
    683
    Which code edition year is applicable and what occupancy group is using the stairway?
  3. HVACQuestions
    Sep 23, 2019
    5
    0
    I'm going off of IBC 2015, occupancy group B
  4. cda
    cda Sawhorse
    Oct 19, 2009
    17,940
    1,240
    Welcome
  5. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    2,052
    683
    This would be an exit access stairway per Section 1019. You may be able to use Section 1019.3, Condition 4, as an option. If not, then the stairway will need to be enclosed,
  6. HVACQuestions
    Sep 23, 2019
    5
    0
    Even though this stair is not a path of egress?
  7. HVACQuestions
    Sep 23, 2019
    5
    0
    Thanks!
  8. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    2,052
    683
    All stairways are part of an egress path whether intended or not. Openings between floors must comply with the requirements of Chapter 7 and it will have exceptions or conditions specific for egress elements per Chapter 10.
    HVACQuestions likes this.
  9. HVACQuestions
    Sep 23, 2019
    5
    0
    Interesting. So a communicating stair that is not intended to be of use for egress, still has to comply with this section? It surprises me that this isn't handled similarly to an escalator opening.
  10. Tim Mailloux
    Tim Mailloux Registered User
    Feb 12, 2018
    201
    30
    I was under assumption that an unenclosed communicating stair which is not part of the egress system (exit access stair) is handled similar to an escalator.
  11. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    2,052
    683
    Start first in Section 712 for vertical openings. It does have requirements for escalators—but escalators only. Other options in this section for this specific application include enclosing it in a shaft, making it an atrium, or making it an exit access stairway.
  12. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,112
    1,053
    Ron has it....An opening with a stair in it is not always egress, but it is always a hole in the floor...And may or may not need to be protected....
  13. Tim Mailloux
    Feb 12, 2018
    201
    30
    Wouldn't section 712.1.9 Two story openings apply to this situation?
  14. cda
    cda Sawhorse
    Oct 19, 2009
    17,940
    1,240
    “””The architect wants to cut another hole in the ceiling to have this stair connect 3 floors“””
  15. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,112
    1,053
    Yep...2 story is easy if no other "holes" to other floors...
  16. Tim Mailloux
    Feb 12, 2018
    201
    30
    I missed that part. Looks like the stair either needs to be classified as an atrium or an access stair. An access stair will be cheaper than an atrium (smoke control) as long as the travel distances will work.
  17. tbz
    tbz Silver Member
    Sep 10, 2010
    538
    26
    Interesting Topic, but I have another question on this topic as to location.
    • So currently there is a communicating stair from lets say 4th floor to the 5th floor.
    • Now lets say on the other side of the office space, not in the same location now wants to install a 2nd communicating stair from the 5th floor to the 6th floor, but neither stair flight or opening are in the same visual sight line, but open air will travel from one area to another.
    • does this change anything since they are 2 different stair flights and not stacked?
  18. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    2,052
    683
    Compliance with 712.1.9 is required. Two-story openings are permitted, but item #6 of that section requires openings serving other stories to be separated by fire-resistive construction as required for shafts. Thus, since the two openings would technically connect three stories, then a 1-hour fire barrier is required on the 5th story somewhere that would completely separate the two openings from one another. If the floor assemblies are required to be of 2-hour construction or more, then the fire barrier separating the two openings must have a fire-resistance rating of 2 hours.
    #18 RLGA, Sep 25, 2019
  19. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,112
    1,053
    Yep...Especially problematic in existing buildings where there may be nonprotected HVAC and other "shafts".....
  20. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    2,346
    368
    Look at the technical report of MGM Fire - majority of fire fatalities was from smoke inhalation and not thermal or fire due to the ability of the smoke to easily transfer to the higher floors when the fire originated in the lobby/1st floor area.
Share This Page
