Home made Chimney Cap
KZQuixote
Sawhorse
Bend, Oregon
Hi Folks,
Getting closer to finishing the addition to my home.
I've been fiddling with this chimney cap on and off for a year.
I finally got it installed yesterday.
attachment.php
attachment.php
The seals are EPDM. I think they'll take the heat. The wood stove is 24' below.
Bill
Note to Jeff:
For some reason the thumbnails in the albums do not work correctly but the pictures display.
mark handler said:
The vents are too close. Exhaust from one will travel down others.
I doubt that, but thanks for the heads up. I've installed a carbon monoxide alarm in the room with the water heater. The wood stove flue is blocked off for now. If the B vent back drafts exhaust from the furnace I'll hear the alarm.
Bill
I do not know how Santa is going to get down that!!!!!
Did you get a chimney permit from Santa first???????
cda said:
I do not know how Santa is going to get down that!!!!! Did you get a chimney permit from Santa first???????
No, I did not consult with Santa or his permit techs but this is a permitted job. I'll post my inspection results as they play out.
I've measured, by touch, the outside temps on these Dura Vent chimneys and found that after extended burns ( more than twelve hours ) I can hold the pipe with both hands. It's warm but not hot. I admit that a chimney fire is a different matter, however if that happens the tiny bit of EPDM that touches the chimney will be the least of my problems.
Here's a close up of the seals. The screws are nonmagnetic stainless steel. The sealant is neutral cure silicone. It will not attack the copper.
Bill
KZQuixote said:
Hi Folks,Getting closer to finishing the addition to my home.
attachment.php
attachment.php
Bill
Note to Jeff:
Nice work. :D
Rider Rick said:
Bill, that is a nice job did you do it?
Hi Rick,
Except for the top sloping roof sections I made it out of left over pieces of copper sill pans. Some of the folds I did with a siding brake when it got complicated I used a hand folder.
Thanks
Bill
U.L listing?
Seriously.
[edit] If this wasn't the work of a good old boy, the majority of those complementing it would red tag it.
And half of those would asschew ICE for letting it go.
Mule,
How do you know what Brasso is? I used to use it a lot back in the day..
KZQuixote,
Nice work! Kinda looks like an air breather on a Hemi 454 big block. :D
brudgers said:
U.L listing? Seriously.
UL listing?
These things are fabricated every day by local sheetmetal shops. No listing required.
KZQuixote said:
UL listing?These things are fabricated every day by local sheetmetal shops. No listing required.
They're a pain to make look good, and that there is some quailty riggin.
Good work there Foggy
