Anyone know how and can calculate the pipe size I need????
So I have another plumbing company coming out to give an estimate.
I want it done right. I have had prices from $100 to $3000.
I have existing natural gas already.
Appears 3/4 inch line running from the meter through most of the attic. One story.
Currently running:
HVAC 75,000 BTU
Water heater 40,000 BTU
I need to either run a separate line for the gas range, or if luck extend what I have.
I want to add a gas range, maybe around 60,000 BTU.
The range will be the last appliance, about 80 feet from the meter.
Trying to figure out cubic feet of gas per hour
Size of pipe needed to the gas range
Does it need a separate pipe run from the meter?
Thanks
I do not know how much pressure is coming into the house. Will try to call the gas company, and see if I can get an answer.
Currently running:
HVAC 75,000 BTU
Thanks
