Housing Inspection Program
Uncle Bob
SILVER MEMBER
Texas
City of Miami, Oklahoma;
"No property owner shall sell, lease, rent, provide, or suffer the possession and occupancy of a residential dwelling unit absent compliance with this Section. Violation of this provision shall be punishable as a misdemeanor in the municipal court. Each day a violation occurs shall be punishable as a separate act.
All residential dwelling units are subject to the provision(s) of this Section upon the occurrence of any one or more of the following conditions:
1. Each time the primary occupant(s) change(s);
2. When the dwelling has been unoccupied in excess of 180 days;
3. When a utility account has closed or been transferred to another person(s);
4. When application is made for a Certificate of Occupancy after a structure has been condemned, determined to be "substantially damaged" under flood-related ordinance(s), or determined to be "dilapidated"."
Now, that's what I call job security for inspectors,
Uncle Bob
"...1. Each time the primary occupant(s) change(s)..."
I see lots of problems with that stipulation. I wonder what a primary occupant is, how many there might be, and whether any occupant must qualify and/or register as such?
Could be, "ain't nobody here but us chikins", verdad?
I the city has an housing inspection program, then they probably issue a certificate of occupancy. If that is the case, Jim, the primary occupants are the applicant and spouse. I have worked in jurisdictions in the past that had housing inspection programs. We used change in ownership and change of occupant as triggers for the inspections. We received a report from the power company when an account changed names.
When it's a change in ownership in a SFD, I believe this type of housing inspection to be fundamentally intrusive; most smart home buyers are going to pay an independent home inspector to cull out problems.
When it's a tenant change in a rental property, maybe. Here, the slumlords are identified by the jurisdiction and proactive housing inspections are scheduled.. annually, I believe.
