Peter Dow
Member
Yes. I am paying attention.RickAstoria said:Peter, Are you paying attention.
True but it is part of the United Kingdom like northern Ireland. Not unless a descendant of William Wallace finally freed Scotland from United Kingdom. Granted Brudgers might know the difference between the parts but Scotland is currently a tad bit more closely tied to England than even Canada politically. That may change in the future but that is a different topic than at hand.Peter Dow said:I'm from Scotland, which is not in England.
Does that explain the lack of building codes?Peter Dow said:I'm from Scotland, which is not in England.
No, they are subjected to the laws and rules (yes building codes) set forth by the UK but only in really recent terms has Scotland had been granted some authority to pass laws within the area of Scotland. Scotland is not as of yet a complete and independent country in the same sense as Canada or Australia is. They just aren't using the ICC model code platform.brudgers said:Does that explain the lack of building codes?
Shirley that's going to pop up in some strange web searches.tmurray said:Peter, How is erection accomplished?
The first point to note is that there are broadly two possible orientations for the HI-bricks when building a wall - the bricks in the "I" orientation or in the "H" orientation.tmurray said:Peter, How is erection accomplished? Since the "bricks" are all interconnecting they would not be able to be laid in courses.
How do you handle corners when two intersecting walls comes together. How do you may a strong corner connection?Peter Dow said:The first point to note is that there are broadly two possible orientations for the HI-bricks when building a wall - the bricks in the "I" orientation or in the "H" orientation.I orientation
If adding another row or course or layer of "I" bricks onto an existing row then one inserts the new "I" bricks from the side, either front or back, in a horizontal swinging motion similar to putting in golf, only one is swinging an "I" brick not swinging a putter. A short dowel section can be added inserted downwards after every brick is swung in place, or it would be possible to leave the insertion of dowel sections until perhaps every 2 or 3 rows of "I" bricks have been placed in which case the dowel sections can be longer.
H orientation
With the bricks being laid in the "H" orientation, the laying of bricks can be done from above or the side or some combination.
The bricks go in easier as Hs than they do as Is but unfortunately, the dowel sections are not so easy to insert in the H orientation when the previous row of bricks can obstruct sliding long dowel sections in.
The dowel sections may have to be no longer than a half-brick's length and inserted vertically into the appropriate dowel shaft of a neighbouring brick and slid along - and you need to do that 3 times - 3 1/2 brick dowel sections (they would slot inside each other to be sure to have maximum strength) to secure one H brick.
Now in the construction of some short structures, you might have or be able make convenient access to slide longer dowel sections in from the side (as I did when demonstrating my model), perhaps you can leave off the corners of walls till last and get clearance to slide longer dowel sections in. There maybe construction methodologies yet to be developed to enable convenient dowel insertion in the H orientation. Or it may be such a pain that way that the I orientation is almost always preferred. I don't know this being very early days and very theoretical before the first full size HI-brick has ever been made.
Sit Ubu sit. Good dog. Remember to behave.brudgers said:Peter, the orifice could lubricate the rod as it is inserted during the mating process.
You may remember I posted this.RickAstoria said:How do you handle corners when two intersecting walls comes together. How do you may a strong corner connection?
So for intersecting walls, then there would be 3 types of corner bricks for walls which meet at right angles depending on how many walls leave the corner2 walls - L3 walls - T4 walls - +This diagram is a rough sketch of a 4-way corner HI-brick. I have not tried to draw any rounded corners to save lots of time.Peter Dow said:one could not use the same HI-brick to form a 90 degree edge as is used for a flat join, but that a special-purpose corner-brick would be required.
Not much really.I've sketched out a design for perimeter defences for a military base. (Link to the For Freedom Forums)I've super-sized a design for a pumped-storage hydro-electric dam. (Link to the For Freedom Forums)I've published some design ideas for armoured vehicles (Link to the For Freedom Forums)So these are my published concepts and designs but I've never actually had a budget actually to build anything, no.The only actual "building" I have done are a few minor DIY tasks around the house and some motor-cycle and car maintenance - that kind of thing.View attachment 660RickAstoria said:Peter, have you design or constructed buildings before?
Ok, that makes more sense now.Peter Dow said:The first point to note is that there are broadly two possible orientations for the HI-bricks when building a wall - the bricks in the "I" orientation or in the "H" orientation.I orientation
H orientation
The main advantage of being able to disassemble a structure or a building is for temporary buildings which you need to relocate every so often, or need to make major changes, to move a wall, add an extension, whatever.tmurray said:Ok, that makes more sense now.Now, typically for new construction materials to succeed they need to solve a problem. From what I can tell your product would be able to be quickly dis-assembled and re-assembled with little waste compared to existing building envelopes. Since we generally design buildings for a 50 year life span there is likely a small market that may profit from being able to disassemble the structural frame. I just don't see the potential market for this product.
Don't get me wrong, I'm not against the idea of innovation and idea but that ideas need to be worked through and I am only critiquing based on what is presented and this is intended to be food for thought. That is in part of why I moved the thread instead of closing it. At this time, I feel that it is currently early in its infancy and needs to be analyzed and critiqued through intense scientific and engineering standards and documents necessary for engineers, architects and building designers would need and all the information required to demonstrate that it meets the codes and all HSW requirements to both the satisfaction of professional standard of care required by the judicial system, the licensing boards, and state & local building departments. When applied to actual buildings, people's lives are at stake and we need to address these issues thoroughly.north star said:& & &
Peter Dow,
Thanks for continuing to post information on this Forum regarding
your design concept......Please do not be intimidated or discouraged
by the Forum members and other contributors......For the most part,
there are a lot of [ traditional ] construction types on here, and
there is an amount of skepticism as well........Sometimes we have a
difficult time in seeing the use & application of new designs that
haven't been tested & used in real world applications.
I will encourage you to keep developing your design......Have you
worked up some pricing structures for the various applications
that you mentioned, [ i.e - temp. stages, ...shelters, ...storage
facilities, etc., etc. ] to see how your various design models
will compare to the existing designs in existence ?
Not quite true. Well... it depends on the building and use. We design buildings with various life-cycle factors but in general the structural should have an overall life-cycle of over 100 years. However, certain overhauls needs to be done at different intervals. However, if you are building a temporary or utility structure which can be replaced in the not to distant future then fine but when we design things like educational buildings, or other "primary structures" on a campus, we build them with endurance in mind. However, secondary or tertiary buildings aren't looked to have high endurance.tmurray said:Ok, that makes more sense now.Now, typically for new construction materials to succeed they need to solve a problem. From what I can tell your product would be able to be quickly dis-assembled and re-assembled with little waste compared to existing building envelopes. Since we generally design buildings for a 50 year life span there is likely a small market that may profit from being able to disassemble the structural frame. I just don't see the potential market for this product.
I am not intimidated by members.north star said:Peter Dow,Thanks for continuing to post information on this Forum regarding
Thanks for your encouragement.north star said:......For the most part,there are a lot of [ traditional ] construction types on here, and
I haven't no and I've no plans to cost this any time soon.north star said:Have youworked up some pricing structures for the various applications
Thank you very much.kilitact said:Peter, I would agree with what north star posted. Sounds/looks like your on the path to a great design.
Hey, I could have moved it to the one Brudgers suggested.Peter Dow said:I am not intimidated by members.The only people that can intimidate me here are the forum moderators because they can move this topic into a less-good forum, already done once, or lock the topic or even ban me.
As for what anyone else posts here, it is like water off a duck's back.
It's not too late.RickAstoria said:Hey, I could have moved it to the one Brudgers suggested.![]()
True but it all depends on how this thread topic goes.ICE said:It's not too late.
Peter, I do hope my comments are seen as discouraging, but constructive as I intend them.Peter Dow said:The main advantage of being able to disassemble a structure or a building is for temporary buildings which you need to relocate every so often, or need to make major changes, to move a wall, add an extension, whatever.So the potential markets for using this more expensive HI-bricks & Dowels technology will be when building big, strong or light-weight temporary structures.
Note that in each example application there would be a need to use different sizes, strengths and materials to make suitable I / H bricks & dowels for the different applications.
- the stage for a music festival on a green field site
- a stadium which needs to reconfigure for different types of events
- vehicle storage and repair garage for oil drilling sites in Alaska / Canada / Siberia / Artic / Antarctic
- underground structures in mining
- flood or earthquake disaster or refugees from war zones or other homeless needing emergency shelters
Where the loads are small and the need is for lightness then the I / H brick would be more like a big tile, a panel or an open tubular frame and as the loads get heavier so the brick size gets more compact, stocky and thicker.
