mark handler
Thats because some worship services are performancesbrudgers said:That's the problem with the IBC. Rather than clarifying that performance does not mean worship, they add another provision.
I'm glad to see that you've finally recognized that those that aren't part of the "some" ain't performances.mark handler said:Thats because some worship services are performances
I did not "finally recognize" anything, access is not related to a performance. There are additional POT rules when there are performances. Platforms are required to have access with or without performances.brudgers said:I'm glad to see that you've finally recognized that those that aren't part of the "some" ain't performances.
By what code section?mark handler said:I did not "finally recognize" anything, access is not related to a performance. There are additional POT rules when there are performances. Platforms are required to have access with or without performances.
Benbrudgers said:At least now you're reading the code. Now read a little further down to 1103.2.1
Then keep reading until you understand 1104.4.2
and reread the thread until you understandWell I will give you the fact that you certainly have a unique approach. Apparently you are content to just keep rambling until you wear everybody out. Whether the thought process is rational or not.What it "they" say - don't confuse me with the facts, I have my mind made up.
I don't see any way to apply the code consistently and maintain that distinction. The same argument about helpers can be applied to any raised area within a house of worship.Lynn said:Mercy I took a few days off and came back and found my question had turned into a three page thread. Thanks for all the thoughts and interpretations. In end result I think I have to go with Dwight B relative to the baptistry issue and my interpretation of the code requires access to the platform. Thanks again for the thoughts and perspectives.
I've never claimed that houses of worship were exempt from the building code. Code officials aren't either.peach said:Churches are exempt from ADA, but not the building code (unless you dont require permits for churches). Needs to be accessible (and I've never had any blowback from churches when I require ramps and lifts).
I'm First Amendment serious. The previous poster was exempting one particular form of religious practice while discriminating against others.fatboy said:Oh please, you can't be serious. Religious denominations have absolutely nothing to do with the the application of codes. Give it up...........it fits or it doesn't.
Which previous poster ?brudgers said:I'm First Amendment serious. The previous poster was exempting one particular form of religious practice while discriminating against others.
