Thanks Ron. I appreciate this info as it will definitely be helpful going forward but I should have clarified that for this project I'm working with 2009 IECC and ASHRAE 90.1- 2007.
Here's where I am with this.....
I have been approached by our mechanical engineer that we should consider utilizing the ASRAE 90.1-2007 compliance path rather than IECC 2009 prescriptive (and I'm assuming the total building performance method option....).
The rationale is that by doing so we can eliminate the airside economizer in RTU's requirement that he is not recommending for this project.
What I'm trying to assess is how making this decision affects me as to the documentation we will need to provide.
As I look through ASHRAE 90.1-2007 it appears to me that a lot of what is contained there has for all practical purposes been copied into the IECC 2009. Haven't been through this with a fine tooth comb but betting that the tables & data align closely..... and thinking that they are basically describing (notes and all) options to prescriptive path, total building performance and ultimately the ASHRAE 90.1-2007 compliance path described in the IECC.
I believe that what I need to be looking into to use the ASHRAE 90.1-2007 compliance path that will ultimately get our engineer away from the airside economizer is near the back of 90.1, Section 11 "Energy Cost Method" but not sure. Do I need to be looking elsewhere? Could the ASHRAE specific prescriptive path (or total building performance method) get him there as well..... maybe because an older code (ASHRAE 2007 vs IECC 2009). What else could I be missing?
If we choose to go ASHRAE 90.1 to give our engineer what he requests, what are we up against?
Any specific coordination going to be required with/ between our engineering consultants?
Does taking this approach lend itself to comcheck with the separate disciplines using their separate analysis?
Can you help me to get my head wrapped around some of this?
Thanks!
