Installing The Exterior Electrical Panelbox
globe trekker
On some Residential installations of the exterior electrical panelboxes, I have noticed that
the installer has inserted wall anchors in to the mortar joints of the brick veneer, vs.
actually drilling in to the brick face itself.
A code instructor has taught / instructed us inspectors to not allow this type of
anchoring to the mortar joints, because, over time, those wall anchors will become
loose and thus, ...dislodge from the wall surfaces.
Is there anything in the IRC or NEC that mandates that these panelboxes be anchored
directly in to the face of brick? Have any of you seen this type of installation?
Do any of you allow this? I am looking at Art. 110.13(A) in the NEC, but this refers
to "wooden plugs".
Thanks!
Thanks Chris for the reference!
Are the mortar joints considered to be part of the exterior surfaces, or ONLY the bricks themselves
( according to code - - NEC, IRC or IBC )
In freezing weather penetrations into the brick itself will subject it to spalling and splitting causing the fastener to become loose and dislodge. Because brick manufacturing ingredients varies so does the strength of the brick however portland cement lime mortar is normally stronger and it's the glue that bonds the brick together and secures it to the ties.
I usually want to see the box or specs for the fasteners approved for this installation.
install to the structure, not the facing (you wouldn't allow vinyl siding to support it, would you)? Yup, you have to flash and provide drainage. Side around the box.
