That used to be in our last residential code as N1101.2.1.2. I thought it was a good section.mtlogcabin said:3. Existing ceiling, wall or floor cavities exposed during construction provided that these cavities are filled with insulation.
Same reply here, it is what it is, do the best you can, and move on. Any additional insulation will only add R-value.fatboy said:I look at it the same as peach........do the best you can do.
That's not stupid, that's smart, I was called to consult on a job on San Francisco, there was a 100+ year old 900 square foot Victorian home set on a lot, property line to property line on the sides, the city would not allow the home to be torn down or altered in any way, it was raised up on cribbing and a new 6,000 (read $6 million) home was being constructed under and behind the old home so that from the street nobody would know that it was nothing but a 100+ year-old little Victorian, yet inside it would be a modern palace. The side walls were beautiful first growth redwood with no WRB that could not be touched, the question was how to insulate those walls? Anything you put in those walls is going to be subject to wetting and mold growth, closed cell foam was proposed by some but mold grows like crazy in styrofoam. I told them it couldn't be done, to get the city to waive the insulation requirement, which they apparently did. In this slideshow idiots sprayed foam around windows, when I first removed the vinyl strips there were mushrooms growing out of the styrofoam in 5 months big enough to look like the belonged in the produce section of a grocery store, with a disabled guy in a wheelchair in one fo the affected apartments, a lawsuit waiting to happen.Tim said:That used to be in our last residential code as N1101.2.1.2. I thought it was a good section.It is no longer there.
Our new code also exempts any "contributing" building in the historic district from meeting any energy requirement. I asked the State, so if they entirely gut the interior, they don't need to install insulation? They say "the code doesn't cover stupid" :smile: priceless :smile:
