Is it required to vent a stove/range?
What if it is not a gas fired appliance? 2425 would not applyopspector said:G2425.8 (501.8) Equipment not required to be vented.... 1. Ranges
Is that only if you don't have the natural ventilation?mtlogcabin said:No a hood is not required but ventilation is. Either an openable window or mechanical sytem which could be a hood.TABLE M1507.3
MINIMUM REQUIRED EXHAUST RATES FOR ONE- AND TWO-FAMILY DWELLINGS
AREA TO BE VENTILATED VENTILATION RATES
Kitchens 100 cfm intermittent or 25 cfm continuous
Bathrooms—Toilet Rooms Mechanical exhaust capacity of
50 cfm intermittent or 20 cfm continuous
And you will not becasue it not requiredjar546 said:I am still not seeing where any type of ventilation is required for above ranges
I don't believe this allows operable windows to satisfy the ventilation requirements.mtlogcabin said:No a hood is not required but ventilation is. Either an openable window or mechanical sytem which could be a hood.TABLE M1507.3
VENTILATION. The natural or mechanical process of supplying conditioned or unconditioned air to, or removing such air from, any space.righter101 said:I don't believe this allows operable windows to satisfy the ventilation requirements.
That is my thought but I am unsure the intent of this section. I am assuming it is a requirement that is met when hoods are installed.righter101 said:I don't believe this allows operable windows to satisfy the ventilation requirements.
Should have started with the charging lanquagejar546 said:That is my thought but I am unsure the intent of this section. I am assuming it is a requirement that is met when hoods are installed.
IF a hood or down draft system is installed then M1503.3 is applicable.M1503.3 Kitchen exhaust rates.Where domestic kitchen cooking appliances are equipped with ducted range hoods or down-draft exhaust systems, the fans shall be sized in accordance with Section M1507.3.
I am starting to think that this is probably the caseDavid Henderson said:required only if manuf requires.
