Is it a shaft? an atrium?
nealderidder
Sawhorse
Sacramento, CA
I'm working on an existing four story office building. The big idea is to open up a two story space (think wide corridor) through the entire building. This two-story common space would connect a southern exterior entry to a northern exterior entry.
Simple enough so far but I'd also like to get some daylight into that two-story space. So pop a couple of large skylights on the roof (16'x16') and build a "shaft" through floors 3 and 4 to connect to the two-story commons.
So is that "shaft" through 3 & 4 a shaft or an atrium?
CBC 713 tells me I need a 2 hour shaft enclosure where connecting 4 stories.
CBC 404 tells me I need smoke control but I can also enclose that shaft with glass at the 3rd and 4th floors if I throw in some extra sprinklers.
I'm thinking atrium and want to surround it with glass but thought I would see if opinions differ.
Thanks,
Sounds to me like an atrium at the first and second levels, and then (2) shafts through the 3rd and 4th.
Not a Cali guy, so I'll stay out of the code sections.
I'm on the road and don't have access to an IBC, but if I remember correctly from a past project, the separation at the 3rd & 4th floor needs to be at least one hour rated, or greater if required by the construction type. California might have different requirements.
