Is or Isn't an alteration?
I do not know of an exemption in the code in chapter 1 or 11B that you exempt.
Is the cost over $150k? if not you only need to spend 20% on access upgrades....
I agree... but I need to determine if it is considered an alteration because that what triggers accessibility requirements. Getting some push back from PW on if it is an alteration or consider regular maintenance.
How much are you doing?
Repair a section or plastering the pool.
I use 100 sq. ft. as a general rule for roofing gyp, bd. or wall plastering.
Does your jurisdiction consider re-plastering of a commercial pool as an "alteration" thereby triggering ADA compliance?
Welcome!! Since no one else has
Ahhh the fine town of Calistoga
Is that your stunt double in the picture??
Your own city, no respect , no respect
If you have time give it a day or two for more responses.
Plus might bring up all the lawsuits because of ada. Our city is trying to upgrade as much as possible
"Ouch"! tile and deck work is an accessible surface, at the least you will need to provide POT to area of work, a lift and compliant parking.
REPAIR. The restoration to good or sound condition of any
part of an existing building for the purpose of its maintenance.
I'd call it a repair.....
Some of the requirements under the ADA do not require updates or remodeling of the facility to trigger compliance for municipal properties. Municipalities are required to make all of their facilities compliant or at the very least have plans developed to do it over a specific period of time. The requirement for a lift for pool access is 1 of these and was not only mandated for municipal pools but also for hotels etc.
