bgingras
I thought it was in the code somewhere, IRC 2009...jacks to be continuous from header to plate? I have a job where all of the jacks are broken to support the sills.
One reason for all that extra wood is to give nailing surface for casings etc.TheCommish said:I am amazed at the number of studs criples doubles put into the walls, first as a waste of material, second lowern the insulation value of the wall.
i have head that, and it maybe true with wide casings, 2.5" raily extends past the jack stud split or striaght and if the casing was wider it sem to me that nailing is not required at the extreem outer permiter is not needed.,jim baird said:One reason for all that extra wood is to give nailing surface for casings etc.Long ago I worked with an old carpenter who always put his door header jacks all the way to the floor.
I worked for an old contractor that framed exclusively with hot dipped galvanized nails. They bend easy and pull hard.jim baird said:Long ago I worked with an old carpenter who always put his door header jacks all the way to the floor.
Just curious on where this information comes from. The sill shrinking 11% seems a bit excessive.tmurray said:The reason that this is preferred is due to the difference in the wood shrinkage. In the direction of loading your jack will shrink 1%, your header will shrink 2-3%, but your sill will shrink 11% or more. It could cause problems with drywall cracking as the lumber dries out.
We used to be proud to be a bit different and American, now for some reason our leaders keep saying we are bad bad peeps who need to change. Just don't get it.tmurray said:That was a joint study done by the Canada Mortgage and Housing Corporation and the National Research Council (Canada). Actually about 5/32 of an inch 2x4 is the nominal size, actual size is 38mm x 89mm. 38mm x 0.11 = 4.18mm X 0.03936996 = 0.16" x 32 = 5/32".When are you guys going to join the rest of us in using a base ten measurement system anyway?
Our building code is in metric, but anytime you do any inspections everything you talk to someone about is imperial. You learn a couple dirty conversion factors really quick, or you end up looking awful stupid when you dont know 1800mm is 6'.Mule said:We use a base ten! Whatever the heck that is! It's just the American base ten...... No really, there are too many old timers, like me, that have been so used to our system that it would be total chaos for me to try to change my way of thinking.Okay let's look at it this way... 11% is just a smidgen over one tenth. Soooo take a 3.5 INCHpiece of wood.
Divide that into ten equal parts, would you agree that each part would be .35 inches?
.35 is just a smidgen over 1/3 of an inch.. agree?
Divide one inch into 3 parts which is pretty darn close to 3/8 of an inch...agree?
Don't you just love this redneck math?![]()
About 1/50th of a 50 lb. box of nails.GBrackins said:1-1/2" sill height x 0.11 = .165". Your math is correct, but your height is off. Of course you could just be messing with us like the guy that says, "if a cubic foot of water weighs 62.5 lbs, and there are 7.48 gallons per cubic foot, how much does a pound of water weigh?"
