Dropstone
As it says, my builder installed the manufacturer of laminate flooring, Select Surfaces, a product line called "Elite" laminate flooring in every floor in this house.
Basically Im hoping that someone can give me some leverage in the argument that this flooring was not intended by manufacturer or allowed by code to be installed through out the house to include wet areas.
The facts....
There are two levels of this flooring. Elite and Spill defense.
In the manufacture FAQS it says...
The laminates in our Elite Collection are moisture resistant. The laminates in the Spill Defense Collection are waterproof for 24 hours. If you are planning to put laminate in your kitchen, we recommend using one of the laminates from the Select Surfaces Spill Defense Collection. These laminates are waterproof for 24 hours, leaving you plenty of time to clean up any spills. We do not recommend installing any laminate in your bathroom, as this is a high moisture area with daily risks of water spills.
The Care instructions say....
Clean your floor regularly.
Exlusions-
The flooring is certainly showing damages in all the wet areas including entries, kitchen, bathrooms. The edges are beginning to buckle upward.
The facts....
- Elite Collection: The laminates in this collection should be cleaned with a damp mop (do not wet mop).
- Spill Defense Collection: The laminates in this collection can be wet mopped.
- Do Not Flood the floor with water.
Exlusions-
- Damage caused by severe impact, scratching, or cutting, fire, water damage, alterations, or any other wear or damage caused by acts of God.
- Although Select Surfaces laminate flooring is moisture resistant, it is not waterproof. Damage caused by water or any other liquids, such as swelling and bubbling, is not covered by the warranty.
- This warranty does not cover defects caused by improper sub-floor / surface preparation (proper installation is assumed to include a moisture test to ensure excessive moisture does not exist in the subfloor). A vapor barrier must be used for those on concrete sub-floors, below grade level or in moisture-prone areas.
- This warranty does not apply to damage caused by water or moisture in the subfloor or underneath the flooring, including but not limited to damage from subfloor hydrostatic pressure (water or moisture under the floor that is transmitted to the surface through exerted pressure) or other conditions that result in water or moisture below the floor.
