JBI
Re: Lateral Calculations for Freestanding Pole Buildings
It's GOOD to be HOME! :lol:
Simply put, I am part of the design/permitting process to the same extent as would an architect on exempt buildings. First, the contractor HAS nothing more involved in the permitting process of a design as I because the contractor is NO more a design professional as I am unless licensed as an architect or engineer. Secondly, I would technically be a contractor but not a construction contractor which can be made any time any moment I decide to deal with that. The contractor (construction) license is for construction not designing. We are talking Plan Review not construction inspection. When it comes to plan review, it is me that is involved on exempt buildings on plans prepared by me on exempt buildings. The contractor is not even involved in the design until bids are made. So it is me, the designer who is ultimately liable for design not the home owner or the contractor. Who has to make the changes to the plans? Me! In fact, architects don't have to supervise the construction of single-family residences. So, I'm involved because A) it is my name on the plans and it is required that the preparer of the documents is identified. B) I'm LIABLE for my design decisions and C) The plans are copyrighted to me which means by federal law, the plans may not be altered by anyone other than the copyright holder.kilitact said:Rick; as a non-professional designer, you would not be part of the permitting process, no debating that point, you’re not a design professional or contractor, so bottom line I wouldn’t have to explain anything to you. It appears that you’re trying to blow a lot of smoke to attempt to cover your non-professional status?Brudgers; the non-professionals in your jurisdiction must like your take. No justification for any design, lol.
As a plans examiner, it would take way too much time reviewing to ensure compliance without the calculations justifying the design.![]()
True indeed. Now we get this diatribe onto this forum record. We all know we have fun. :lol:John Drobysh said:It's GOOD to be HOME! :lol:
Ok. I haven't read all rbrunk's posts.mtlogcabin said:Rick and kilitact you two have been disagreeing on this subject for over a year now. Rick you started this exact discussion on another post that you are repeating here. Agree to disagree and grow up and quit acting like lawyer wantabe's. It's not the type of home I grew up in nor want to live inBoth of you have a lot of proffessional knowledge to share from your different backgrounds that all of us can learn from and your constant arguring over liscensing requirements detracts from the original post.
It is a commercial IBC structure and a pole building by its nature is out of the scope of 2308 for light frame construction. rbrunk will decide who can submit the design in accordance with HIS local or state laws.
Rick without designing it you could have been more helpful by giving advise to rbrunk on what to ask for from the designer for this structure
1. It is accessory to the fire department. (Should have posted this under commercial category)
2. It is approx. 480 square feet with 4, 6x8 posts located at each corner.
3. Two parking bays for fire department maintenance vehicles only.
4. Seismic zone D
5. Total height approx. 15'-16' to ridge of a 4/12 roof built from engineered trusses.
6. Clearance under beams from finish grade is 8'.
These days, I don't have a jurisdiction in the sense that your response appears to assume.kilitact said:Brudgers; the non-professionals in your jurisdiction must like your take. No justification for any design, lol.As a plans examiner, it would take way too much time reviewing to ensure compliance without the calculations justifying the design.![]()
These days, I don't have a jurisdiction in the sense that your response appears to assume.brudgers said:kilitact said:Brudgers; the non-professionals in your jurisdiction must like your take. No justification for any design, lol.As a plans examiner, it would take way too much time reviewing to ensure compliance without the calculations justifying the design.![]()
I require calculations to justify the design, thats a given, on exempt or non-exempt buildings, all engineered calculations will be stamped and sealed. I don't base my review on the quality of the individual nor do I spot check calculations. When I complete my plan review and sign my name on the plans, I will be assured that I've reviewed the complete submittal for code complaince, not just spot checked, thats my CYA.These days, I don't have a jurisdiction in the sense that your response appears to assume.When I did, I didn't ask for calculations as a CYA method.
If I got calcs from a design professional, I reviewed them.
When I just got a seal, I spot checked areas of concern by running my own calcs.
The adequacy of the design was typically a function of the quality of the individual, not their particular license
Wow, you have time to run complete calcs?kilitact said:I require calculations to justify the design, thats a given, on exempt or non-exempt buildings, all engineered calculations will be stamped and sealed. I don't base my review on the quality of the individual nor do I spot check calculations. When I complete my plan review and sign my name on the plans, I will be assured that I've reviewed the complete submittal for code complaince, not just spot checked, thats my CYA.![]()
What do you do? Spot check and spot charge for plan reviews, that seems like a half-a.. approach. A plan review IMO means reviewing the entire submittal.Wow, you have time to run complete calcs?Or do you just check a box on a form?
brudgers said:First I check my plans.Then I sign them.
Then I seal them.
Then I enjoy personal liability until repose.
Back when I reviewed plans, I endeavored to follow the law.
If a building was exempt, I checked it based on the law not my personal views about what ought to require a licensed professional.
My goal was safety, not bureaucratic abuse of the public trust.
Exempt buildings by unlicensed designers were generally more trouble to review.
Because I took my job seriously, I enjoyed the challenge.
That’s sounds like my mantra, except for the sentence, "that exempt buildings by unlicensed designers were generally more trouble to review". I’ve had homeowners submit calculations that were as good, if not equal to a design professional’s calculations.Back when I reviewed plans, I endeavored to follow the law.If a building was exempt, I checked it based on the law not my personal views about what ought to require a licensed professional.
Thank you for steering this topic back to my original question. All responses were appreciated and many were quite entertaining as well.mtlogcabin said:Rick and kilitact you two have been disagreeing on this subject for over a year now. Rick you started this exact discussion on another post that you are repeating here. Agree to disagree and grow up and quit acting like lawyer wantabe's. It's not the type of home I grew up in nor want to live inBoth of you have a lot of proffessional knowledge to share from your different backgrounds that all of us can learn from and your constant arguring over liscensing requirements detracts from the original post.
4. Seismic zone D
me thinks you need to reread your original post :roll:I just made our local fire marshall go get some engineering for his proposed maintenance vehicle parking structure and he thought it was a bit much for such a simple structure.Any input will be helpful.
