Lawn Sprinkler Installation - Domestic Water
State or Country
Georgia
Owner - Contractor - Design Professional
Owner
[test thread]
We are having a lawn sprinkler company install a new system for our lawn. They will be tying into the domestic water supply because our development does not have reclaimed water. Is a permit required?
You probably need to check somebody local because requirements about tapping into water systems are quite local and very from place to place.
Isn't the Clean Water Act (CWA) enough?
Yes but. There are a thousand regs in place to protect the environment and people. But someone needs to verify the installer is following the rules. That’s where the permit comes into play.
Varies by region. I do not know of a uniform code that compels a permit. However, here in California there are many jurisdictions that require the purple-colored irrigation pipe in anticipation of reclaimed water becoming available at a further date from a municipal utility. If it’s a required spec, then there’s probably a permit associated with it, even if it is just a condition on a planning department approval.
