Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,318
I have a electric double oven (light duty appliance) installed without a hood in a commercial kitchen. A type II hood can be installed over a light duty appliance that does not produce grease or smoke per 2009 IMC 507.2.2. Otherwise, if it produces grease or smoke then it would need a type I per 507.2.1. So in this case, if you assume the oven does not produce grease or smoke then it would need a type II hood, and if you assume the oven does produce grease or smoke then it would need a type I. I read this as either way a hood must be installed. So how do you decide whether an oven will produce grease or smoke? Apparently someone has at this place, namely the architect and plan reviewer, and why no hood at all? Obviously when at the 11th hour mister inspector shows up and asks these questions his popularity suffers so any guidance is appreciated.
