Living on the Edge - Wet Use Joist Spans in the IRC R507
Talk about cutting it close; check this out. In the IRC Table R507.6, a 2x8 nominal Southern Yellow Pine floor joist has a maximum span of 11' 10" @ 16" o.c., which is cutting it close, to say the least. There may be a safety factor built in, but certainly not a practicality factor, especially when you look at how close the deflection is to failing.
What are your thoughts on this? Did you think the tables were more conservative than they are?
This is the expected outcome when the span is deflection controlled. The safety factors are built into the allowable stresses and the design modulus.
Cheers, Wayne
Codes should not be a guide for good design, but merely a minimum. Meeting code earns a letter grade of D.
Wet use would be for decks, which seldom support plaster ceilings. IBC Table 1604.3 allows L/240 deflection for non-plaster ceilings, and L/180 deflection for no ceiling.
I understand & agree. This is the difference between minimum safety and good design for the longevity of the structure.
Unless you're running herds of elephants around on these joists, I don't think designing for L/360 deflection is going to decrease the longevity of the structure.
Cheers, Wayne
