Masonry Piers Construction In Residential Construction
globe trekker
I have an addition being proposed to an exisiting residence.
The addition will be approx. 400 sq. ft., conventional foundation, to have a flooring system supported
on masonry piers. The CMU's for the individual piers will be be 8" x 8"x 16" [ 3 high & grouted ] with one -
5/8" re-bar in each cell of the CMU's and then poured concrete into each cell also.
The design area has a 2" frostline, Seismic Design Category " B ", soil bearing capacity = approx. 2 - 2.5 k.
This addition is going onto a residence in a lower economic area [ essentially a shack ]. None-the-less, I
am seeking information on the construction of the masonry piers. Section R606.6 in the `06 IRC
doesn't provide me with what I am looking for.
QUESTION: In this particular design category, must the piers be anchored below grade or can the
CMU's be anchored to an 'above grade' poured foundation [ approx. 4" thick x 16" wide x 16" long ],
with the steel re-bars set in this area and then tied into the individual CMU's?
FWIW, the exisiting structure is not anchored 'below grade', but it IS substantially old, ...before
any codes were used in this area. Also, I cannot request a DP or any kind of engineered plans on this
project because of, ...well, I just cannot! I DO have certain limitations in place.
As always, if you could please direct me to the applicable sections in the IRC or IBC. I HAVE read
Section R403.1. and viewed Figure R403.1(1), but am still unclear.
Thanks for your input! ;)
R E Q U E S T: If you plan to provide some negative comments or input, please save it for
another thread. I am trying to manage this project as best as I can and I simply do not need the
negative input. PLEASE, only positive/constructive input and assistance and code references.
Again, thanks for your help! :)
Re: Masonry Piers Construction In Residential Construction
How's this work for you?
2006 IRC
R407.3 Structural requirements. The columns shall be restrained to prevent lateral displacement at the bottom end. Wood columns shall not be less in nominal size than 4 inches by 4 inches (102 mm by 102 mm) and steel columns shall not be less than 3-inch-diameter (76 mm) standard pipe or approved equivalent.
Exception: In Seismic Design Categories A, B and C columns no more than 48 inches (1219 mm) in height on a pier or footing are exempt from the bottom end lateral displacement requirement within underfloor areas enclosed by a continuous foundation.
R403.1.1 requires the footings to be at least 6" thick, and limits projections to the thickness of the footing.
R403.1.4 requires footings to be at least 12" below undisturbed ground surface
