Hold the alt key down and punch the numbers into the numbers keys on the right of your keyboard then release the alt key, not the numbers on the top.DRP said:Chris, I'm not following what you did.
Post Deleted.dhengr said:I’m testing too.° ∑ ∞ ± µ ∫ ∇ ° ∂ θ ∑ φ π Δ τ ⊥ λ ν ξ ρ σ Σ ς Ψ ψ Ω ω ε
{42 x 3}[ Eeff /E], Δ = 5wL4 / 384 EI Δ = 5wL4 / 384 EI
Δ = 5wL4 / 384 EI, The deflection for a uniformly loaded simple beam. To keep the units straight, w must be in lbs./inch and L must be in inches. Or, w can be in lbs./ft. and L can be in feet, but then the numerator must be multiplied by (1728 ʺ3 / ʹ3).
