medical grade wiring?
JPohling
San Diego
National orthotics provider/manufacturer looking at a TI in one of the office buildings that we work in. We advised them that they would need medical grade wiring in the "exam/fitting" rooms. 2013 CEC. This is not a medical office building. The user claims that they are like a glorified shoe store and they believe the medical grade wiring is not required. What would be your interpretation? This is a B occupancy not an M.
JP,
How does the AHJ define Orthotic Care ?......Medically, or like the
"glorified shoe store" analogy ?
Article 517 [ from the `14 NEC ] does not specify Orthotics
as a Health Care Facility........IMO, ...if the AHJ can accurately
define & support that definition in the NEC [ i.e. - Article &
section ], then they may have a basis to require the medical
grade wiring & devices.
Does an Orthotic Clinic have electrical devices that will come
in to contact with patients ?
If it were me making the decision, I would want to know
more about the fitting of any devices for the patients,
before I would require medical grade wiring & devices.
JP...There is a good article by Fred Hartwell I think on HC wiring if you can google it or PM me and I can probably email it....And you may have to go to your state regs to see what they define as health care. Here we call it for eye doctors if they are doing exams, but not just glasses (I can't remember the difference between optometrist or opthamologist)
Still looking for something I had from the DPH....
7 ~ 7 ~ 7
In performing some reading on Orthotics, ...there are devices called
"Powered Orthoses that can produce electrical stimulation to patients
when installed on them........I do not know if this electrical stimulation is
provided thru the premise wiring, or by battery powered supply in
the orthoses themselves.............If by premise wiring; which I
suspect is likely, ...then IMO, "Yes, medical grade wiring" would
be required.
Here is a link from the 2005 IEEE regarding "Powered Lower
Limb Orthoses":
http://kines.umich.edu/sites/webservices.itcs.umich.edu.drupal.kinesprod/files/resource_files/Sawicki2005.pdf
7 ~ 7 ~ 7
steveray - Sounds like critical equipment protection? Not so sure the orthotics guys fit that mold (pun also intended...).
"Powered Orthoses that can produce electrical stimulation to patientswhen installed on them.
How is it different then a TENS unit in a physical therapy or chiropractic office?
I think you need more info on the equipment providing the "electrical stimulation" to help with documenting your decision.
Are they sitting/laying in a chair that is electrical powered for movement? Then I say yes........
I agree that more information on the level & depth of services provided
at the new "B occupancy" tenant will provide is critical in this decision
making process........Simply because the Occupancy designation is a
"B", does not limit what type of device might be applied to, or come
in to contact with their patients.
If the proposed new tenant will be "manufacturing" something to
customize to each patient, ...what are the limits of that manufacturing ?
Also, ...if an approval is granted for Non-medical grade wiring & devices;
in the Examination Rooms \ Areas, ...who's to say they won't alter their
manufacturing process down-the-road, to meet the needs of their
patients, and have some type of tethered \ connected electrical
orthoses connected to a patient ?
See the definitions of patient care area and health care facilities in the NEC....I can't copy and paste them...And then look at what your state defines as health care facilities. It includes psychiatric, so orthotic might not be a stretch.
Thanks guys! The floor plan screams medical office. I will stand by my recommendation to use the medical wiring.
So does an
Eye exam room for glasses need med wire
Chiropractor room need med wire
Physical therapy clinic need med wire
Etc
cda,
In each of your Exam Room scenarios, ...what type, if
any, ...electrically operated or connected devices \ equipment
\ furniture \ Exam Tables or Chairs will come in to contact
with the patients ?.......Also, ...what one "patient care provider"
offers as treatment; and their use of treatment devices or
equipment may not be the same as others.
It is similar to the construction industry, in that, not all
construction is performed in a safe & compliant manner.
The same applies to any profession !
IMO, ...I believe that **JPohling** has justification to
recommend the Medical Grade wiring...........He may not get
it, but I believe that he should at least recommend it.
We have provided him with enough information to
substantiate his position.
Also this group does more than orthotics. Prosthetic's are a major portion of their business. I can see them changing things up easily to go that route. Also this suite is clearly planned as a medical suite. When this tenant vacates it is highly likely that another medical user will occupy the space.
I wonder what the cost increase is. Reading Mike Holt's information shows significant expense comparing a standard commercial type receptacle to a medical type, but they are not required everywhere, just in treatment rooms.
I would give a SWAG of 4 times the cost per medical outlet, for however many exam rooms they have.
Anyone know anything further?
Brent.
Hospital grade devices are not required in treatment rooms. Right now here 250' 12/2 MC is around $95, 250' of 12/2 MC-HCF is around $150. The adder for treatment rooms is around 30%.
just a quick answer here I can look it up when I get a second but I believe the answer lies if they are doing an invasive medical procedure like operation, colonoscopy, etc. the medical wiring issue kicks in. This seems to be in keeping with the majority of the comments posted here.
