metal threaded onto pvc
codeworks
Gold Member
South Texas
06 ipc. can t find it, know it's not ok. metal male fitting ( brass or steel) threaded onto female plastic fitting. any help with locating code section, thanks
codeworks said:
06 ipc. Can t find it, know it's not ok. Metal male fitting ( brass or steel) threaded onto female plastic fitting. Any help with locating code section, thanks
09 ipc 705.19
In the `06 IPC, see Section 705.18.4.......An approved adapter fitting
would be needed for the transition between the different materials.
What is the pipe being used for? If the threads match, why is it a problem? The only thing that I can think of is dissimilar expansion properties.
ICE, FYI
If you run male metal threads into a female plastic fitting it's very easy to split the fitting.
CPC 2010
606.2.2 Plastic Fittings. Female PVC screwed fittings
for water piping shall be used with plastic male fittings
and plastic male threads only.
pete_t said:
ICE, FYIIf you run male metal threads into a female plastic fitting it's very easy to split the fitting.
CPC 2010
That was a major issue with the early Blazemaster CPVC sprinkler pipe before they put the metal inserts in the 1 x 1/2 adapters for screwing in the heads.
