Minimum bar top overhang
khsmith55
Bronze Member
Glenwood Springs, CO
Given an accessible space at "bar" seating, what would the minimum overhang be? I can't find any requirement in ANSI A117 but I'm leaning towards 17" based on that required for the "use" of a drinking fountain. Any help or direction is greatly appreciated. Thanks in advance.
  • Like
Reactions: JBI
You do raise an interesting point. Bar "seating" is often not actually designed to be oriented facing forward with knee space. Even if you are not in a wheelchair, it is designed to compel you to sit "side saddle", or even just to stand.
In that case, would a 48" wide side approach wheelchair space (no knee space) at a 34" high bar counter be equivalent facilitation?
  • Like
Reactions: JBI
That is an interesting point, considering one advantage (and possible reason) for the high bar top is to provide some security to the bartenders...
Looking at the ANSI A117 commentary, they recommend a minimum of 60" long to provide a "companion" seat at the same elevation. I would take this as an implication that they suggest a forward approach for two 30" wide spaces, one being "accessible, thoughts?
So, is it to be shoulder to shoulder or face to face when drinking together?
Theaters require alignment of shoulders with companions.
