incognito said:
I see no mention in the code in regards to comments that I can or can not make as to what I want the RDP to provide. As far as liability I have none, nada, zero unless I knowingly approve something which is not code compliant. Even then I can reasonably argue that as the AHJ that I consider the design to be an acceptable technique. After all, it has been designed by a RDP. I will ALWAYS leave a paper trail that goes directly to the RDP.
As far as what you can request they provide or not, I usually fall back on IRC 106.1.1
R106.1.1 Information on construction documents. Construction
documents shall be drawn upon suitable material.
Electronic media documents are permitted to be submitted
when approved by the building official. Construction documents
shall be of sufficient clarity to indicate the location,
nature and extent of the work proposed and show in detail
that it will conform to the provisions of this code and relevant
laws, ordinances, rules and regulations, as determined
I am not over picky, and I do proudly use Milton's rule, but sometimes, what I get is bad.
My general speech on really bad plans is this:
The plans should be clear enough that a compentent contractor not familiar with the project should be able to order materials from the plans and built it, with a reasonable degree of accuracy.
Should we have a "submission of the month" category on the forum?? With all identifying information redacted?? I trust that most of the RDP's that contribute to this fourm care enough about work product to produce something good. The fact they are engaged in debate and up to speed on code and legal issues tells me that you guys care to a large degree. I get things that haven't even had an internal second look from RDP firms. They use me as the quality control. Which, I don't mind, but if I was spending these sums of money on professional architecture, I would expect a good work product.
Hope everyone has a good weekend.
