Missing Ground Wire - Large Commercial Lighting Project - Exterior / Industrial
ElectroMan1985
San Francisco
We are working on a very large exterior lighting conversation at an industrial site. Replacing 400W + 1000W HID fixtures w/ new LEDs. The problem is, the existing 40FT+ wood poles don't have an existing ground wire. To add a ground to these poles would require very expensive and complicated infrastructure upgrade and would not be approved.
Question: Is this a circumstance where the functioning/existing electrical infrastructure that does not have a ground wire can be 'grandfathered' in with the new LED lights or does it require a complete upgrade to the lighting system?
Any specific NEC code you could point us to?
Are you working with a city building electrical dept,
That requires permits and inspections ?
Not into electrical, give it a few days for some replies,
Seems like for safety they should be there.
Sometimes just swapping fixture does require a permit.
It requires a permit in my jurisdiction, and it would require grounding. It seems unlikely that adding grounding would be infeasible, but I don’t know all the details of your project.
You can start with NEC 250.4 which basically says you need grounding and bonding. There are times where you just have to upgrade a lighting system or any system to meet current code requirements for safety. There is no excuse for continuing an unsafe system when it it retrofitted with new equipment.
Refer to these links
https://forums.mikeholt.com/showthread.php?t=142600
https://forums.mikeholt.com/showthread.php?t=80939
There seems to be credible arguments why grounding is not needed for each lighting pole.
The first link is not relevant to the OP. The first link is about ground rods at light poles, which by the way is not required and a waste of labor and materials.
The second link is more credible but is overwhelmingly in favor due to the actual code requirements. In the second thread, the engineer admitted he was wrong and they ran new conduit with an equipment ground.
There is no other code compliant alternative. I wonder if Mark K even read the threads from Mike Holt's forum.
the best thing to happen here is that everyone will look at the differences between bonding and grounding and where each is needed. An equipment grounding conductor is needed for the lighting project. Mike Holt's courses does an excellent job of showing the dangers using ohms law.
