Mech
2009 IBC, IMC, IPC, IECC
2009 A117.1
Project located in Pennsylvania
Two re-purposed modular buildings (trailers) have been set on blocking (w/o permits) and are being used as a control room at an industrial plant. Now that the plant has been caught, they need to get a CO.
Does this fall under the scope of the IBC?
My thought is yes, and since the trailers will be used for more than 180 days, they do not fall under the temporary structures category.
I assume the trailers:
1. Need piers or a foundation and then anchors as well - IBC
2. Need proper egress and lighting - IBC, A117.1
3. Need compliant restrooms - IBC, IPC, A117.1
4. Need to comply with the energy code - IECC
Am I correct in my thought process?
Any help would be appreciated.
Thanks
2009 A117.1
Thanks
