Inspector 102
New home less than 1 1/2 years old. R-19 exterior wall insulation assembly with house wrap, vinyl siding. High effeciency furnace and vinyl clad windows. The problem is the exterior walls and windows seem to have excessive moisture causing frost on receptacle cover plates. No reason for excessive moisture inside house but test was 42% humidity. Located in Northern Indiana where temperatures currently are about 10 degrees. I have told the homeowner to run furnace fan continuously and see if this changes anything. He is also going to do a check with a thermal imaging camera from the local fire department to see if anything is obvious. Looking for suggestions on other possible causes for this occurance.
