This is the second page of the attached file. I can't figure out why it says that motorized smoke dampers are not required? When the code mentions smoke dampers, does it refer to motorized smoke dampers?
How can the fusible link of a smoke damper detect smoke?…But if a code section just says "smoke damper," either a fusible link damper or a motorized damper can be used.
This is inappropriate. keep it positive eh. May I propose you offer apologies, or are you too proud?:doh:
Took too many stupid pills this morning. Me go now.
smoke dampers will be actuated by a smoke detector nearby or in some cases by the fire alarm. The fire alarm system has the means to shut smoke dampers by zones or throughout depending on the fire fighting strategy. @tmurray has offered a good explaination.How can the fusible link of a smoke damper detect smoke?
Well in that case I'm the one who should apologise for not reading the room right. Darn it, I'm being humbled again.Mac, YCC was self-effacing, I think his ‘doh’ comment was directed at himself and his own later realization that the subject was smoke dampers, not fire dampers.
I would not be surprised if someone has already invented some kind of spring-loaded smoke damper on a magnetic hold-open that get gets actuated by a smoke detector. However, I don’t see it as practical - - it would need to be manually reset every time the detector is tested or actuated - - too much labor.
There are two locations in the code where there are opposite requirements (shut-down and not shut-down).This is inappropriate. keep it positive eh. May I propose you offer apologies, or are you too proud?
This is one of the areas of the code that is the most underexplained and outdated.
The chief plumbing/building inspector at the city of victoria gave us a webinar last year. ....
Yes, all smoke dampers are motorized.
What that is referring to is certain smoke control systems in high rise buildings.
Normally, smoke or combination smoke/fire dampers need to close based on a signal from an adjacent smoke detector. However, if the duct is part of the smoke control system, like pressurizing a space to prevent smoke from contaminating it, even if there is smoke in the space, we need the duct to remain open to minimize its ingress into the space. But these ducts are still penetrations in the fire separation that need to be protected from fire, so a fusible link damper would be required to ensure it operates when exposed to fire.
