NEC 334.15(B) Chris Kennedy Code Change 2023 NEC
Forum Coordinator
Somewhere Too Hot & Humid
The undisputed King of Romex, our own Chris Kennedy is sponsoring this 2023 NEC Code Change.
(B) Protection from Physical Damage.
Cable shall be protected from physical damage where necessary by rigid metal conduit, intermediate metal conduit, electrical metallic tubing, Schedule 80 PVC conduit, RTRC marked with the suffix -XW, or other approved means. Where passing through a floor, the cable shall be enclosed in rigid metal conduit, intermediate metal conduit, electrical metallic tubing, Schedule 80 PVC conduit, RTRC marked with the suffix -XW, or other approved means extending at least 150 mm (6 in.) above the floor. Conduit or tubing shall be provided with a bushing or adapter that provides protection from abrasion at the point the cable enters and exits the raceway.
Type NMC cable installed in shallow chases or grooves in masonry, concrete, or adobe shall be protected in accordance with the requirements in 300.4(F) and covered with plaster, adobe, or similar finish.RealRomex.jpg
That picture of Chris looks like jar stole his bran muffin from his Batman and Robing lunch box, better put it back!
