Is it really a controversy?See the picture above.
If you were handed an electrical drawing for a control box that you had to supply the line and load of the object in the picture above and the line side was for a single phase motor. Would you consider it a problem if you were required to use the device in question to disconnect both the hot and neutral?
As an inspector, would you question the switching of the neutral?
