    Dismiss Notice
Need clarification on Ontario building code for guardrails
Discussion in 'Canada' started by mhorton, Dec 16, 2019.
  1. mhorton
    mhorton Registered User
    Dec 13, 2019
    4
    0
    I'm trying to understand what is meant by section 3.3.1.17 'Guards' of the Ontario Building Code.
    link to building code: http://www.buildingcode.online/328.html
    Where it states:
    "openings through any guard that is required by Sentence (1) shall be of a size that will prevent the passage of a sphere having a diameter more than 100 mm unless it can be shown that the location and size of openings that exceed this limit do not represent a hazard."
    Can someone clarify if this is referring to just the vertical member spacing of the guardrail or does this also apply to the triangular spacing from the top of the thread to the bottom of the rail?
    Thank you!
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,871
    992
    Hunh...Thought I replied to this earlier....IBC allows a 6" sphere at the triangle, 4" elsewhere....Not sure about ontario....Are you related to Tim?
  3. mhorton
    Dec 13, 2019
    4
    0
    Oh! thank you, I just realized your reply. Also sorry I don't know Tim.
  4. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,743
    474
    It also applies to the triangular spacing created by the bottom rail of the guard, the stair riser and the stair tread. There is no similar allowance for a 6" sphere in the OBC.
  5. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,871
    992
    You Canadians are tough!
  6. tbz
    tbz Silver Member
    Sep 10, 2010
    536
    26
    I have to do some digging, been sometime since I worked on the Canadian Code, but there is a research paper floating around up north that specifies the different configurations that are allowed. I believe the supplier is George Bezdan and the website link is https://www.geobezdan.com/national-building-code
    They could get you to the correct information faster than anyone here I believe.
  7. mhorton
    Dec 13, 2019
    4
    0
    Okay, thank you all for your comments. I'm currently trying to edit a stair detail for precast concrete. I'm now curious about what some solutions are to meeting this code and what that would look like in the form of a detail. It sounds like I have no choice but to extend all of the vertical members into the concrete, but it sounds quite laborious.
  8. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,743
    474
    Typically that is what we see. For the cable rail assemblies, like the Geobezdan, most people plow out the stringer so the tread in impeded in the full 2-by (usually 2x12).
  9. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,743
    474
    The approval from Quispamsis on this website is me!
  10. JPohling
    JPohling Sawhorse
    Aug 16, 2011
    1,062
    122
    Looks like you have some difficult to pronounce names up your way!
  11. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,743
    474
    Quis * pam * sis
    Most people mistakenly place the emphasis on the "pam" syllable, but there is only a very slight emphasis on the "Quis" syllable.
    JPohling likes this.
Share This Page
