Yikes
I haven't personally done much electrical system design - - I usually leave that to the electrical engineers. But with more than 9000 structures (including 6000+ single family residences) destroyed in the recent Eaton Fire (Altadena, CA), I'm trying to wrap my head around the implications for the future utility service sizing for the community, assuming current code is not relaxed.
Our CalGreen and Energy codes are currently requiring the following:
The dumb questions:
Is the bottom line that the service gets sized for #1 and 2, then upsized again 20% more for #3?
Or is it even more than that - - does it mean that we must first sum both the power draw of the house, and the power supplied by the PV and/or battery, and then make sure that doesn't exceed 120% of the busbar rating.
If the service gets upsized for power from two sources, does that mean the sizing of everything else "upstream" on the utility side needs to get upsized too?
I could easily see how thousands of homes in the 100 year old community that previously had a 60-100 amp service may not have a 200+ amp service, which when applied to thousands of dwelling on hundreds of city blocks would potentially trigger an entire redesign of the Edison utility service to the whole community - -right when they are trying to replace the burned out utility service in-kind. Am I wrong on this?
- All replacement homes that previously utilized gas for heating, cooking, clothes drying and and hot water must now be wired to be ready for 100% electric (e.g., heat pumps, induction ranges, etc.).
- Main panel must have a dedicated space for a 40 amp future EV charger.
- California will require solar PV and/or battery storage.
Where two sources, one a primary power source and the other another power source, are located at opposite ends of a busbar that contains loads, the sum of 125 percent of the power-source(s) output circuit current and the rating of the overcurrent device protecting the busbar shall not exceed 120 percent of the ampacity of the busbar. The busbar shall be sized for the loads connected in accordance with Article 220.
The dumb questions:
