steveray
Concealed spaces not requiring sprinkler protection
I have a new firehouse that is trying to eliminate sprinklering the attic....I assume the above section is what they are using......Has anyone here defined "limited access"? It is a non combustible attic (cold formed metal framing and steel decking) But I tink I have issue with the limited access part as there is a man door and catwalk on that side....Any discussion or input would be appreciated, I will try to see if there is anything in the newer codes that may clarify as well....Thanks!
