Circuits for exterior pool motors must have an insulated ground.
NM is allowed in the interior of a dwelling unit for the above circuit.
Does your jurisdiction require an OCPD where the transition is from NM on the inside to pipe/THWN on the exterior so that the "branch circuit" has the insulated ground?
Do you allow any type of disconnect other than an OCPD for this transition on exterior pools for SFRs.
